Use a ruler and basic math. Very easy to figure this stuff out.
Nov 24, 20 5:55 am ·
mightyaa
Tech even makes it easier. You can use software like bluebeam, calibrate the ruler, and draw scaled dimensions over the pdf. Or most drafting software can import a graphic and you can change it's scale factor until you can use the dimension tool.
Dimensions
Please, does someone know the exact dimension of Shibaura House (SANAA) ?
I searched all over the internet, but all I found was different dimensions, wrong dimensions or even not dimensions at all.
I’m a new architecture student and I would really appreciate it if you could help me with this. Thank you.
Mighty, I am very aware of this. I felt the OP needed to take things one step at a time. Cheers
make it up
