Type IV construction (Heavy Timber) - MAXIMAL SPAN?
Hello,
I would like to ask if somebody know the maximal span between loaded walls for the normal ceiling on the first floor when there are 2 and a flat roof.
Type IV construction (Heavy Timber).
Thank you in advance.
May 26, 19 1:57 pm
what type of gravitational environment is this in?
May 26, 19 2:50 pm  ·
On billion solar mass black hole
May 26, 19 3:52 pm  ·
Only type IX construction is allowed on celestial bodies with mass exceeding 500,000,000 sol, so high density ceramic carbon fiber composite should be used. Max span 32^-10 parsec.
May 26, 19 10:13 pm  ·
what’s the depth of the structure?
May 26, 19 3:06 pm  ·
Superfluous Squirrel
Really far
See the Richmond Olympic Oval:
https://en.m.wikipedia.org/wik...
May 26, 19 4:00 pm  ·
Thanks everybody!
May 27, 19 5:40 am  ·
columns every 10’ is typical. You can get away with 20’ spacing if you bribe the right AHJ.
May 27, 19 5:46 am  ·
There's not enough information in your question to give an informed answer.
The replies above are either jokes or speculation based on the limited info available. They're mostly useless.
10'-12' though, as a rule of thumb.
May 28, 19 5:06 pm  ·
BulgarBlogger
There are certain minimum dimensions in the building code for heavy timber cross sections...
May 28, 19 6:19 pm  ·
