The largest glass panes on Apple's headquarters are 47 feet x 10.5 feet. They're curved.
If you mean a size for which you might reasonably find a source that doesn't involve building a factory to specially produce it: then approximately 11 by 6 feet is the largest I've seen on a more mundane non-starchitect sort of project.
For glass partition supported at top and bottom only, GANA (glass association of north america) has an 18 foot limit. At that size, glass needs to be fully tempered and 1 inch thick.
Apr 24, 19 11:21 am ·
Largest Piece of Single Pane Glass Interior
What is the largest piece of single pane glass you have seen installed in an interior application?
Size doesn't matter. It's how you use the glazing that matters.
