How to convert scale
105
ordo
I am trying to scale a house blue print to actual size and can t figure out the math.
So the blueprint states:
SCALE: 1/4" = 1'-0"
If I were to convert 119 to actual size how many feet would that be?
Please show the work also.
Jan 14, 18 2:35 pm
Use math.
Jan 14, 18 2:37 pm
ordo
Wow and i was only using Ematics no wonder
119 x 3.14(pii) / 1/4” = 10’-5”
Jan 14, 18 2:44 pm
ordo
Doesn't seem right because this is the length of the house. I'm pretty sure it's not 10 feet long.
It’s a small house, likely a tricked question. I’d bet it’s a a plan of a kids playhouse. Trust me, I’m an architect.
ordo
No actually is supposed to be a very large house. My father was supposed to get it built. He purchased a 1 acre property to build it on. It's an actual 6 page draft.
I don’t think so. 6 pages are typical for
jla-x
Non is correct. It's just a small house. Dad lied.
Actual size: 12"=1' or 1000mm=100cm=1m
Jan 14, 18 2:52 pm
ordo
The blueprint is on a scale so it's not 12" = 1'
You needed actual size, I delivered.
But okay...here's a tip: How many blueprints would you need to lay side by side until you reach the actual length of the house?
ordo
A tip can't be a question just like 1' is not actually 1' on downsized scale....
Of course a tip can be a question if it helps you to clarify your thoughts, but in this case that's rather pointless...my bad.
It is very simple, measure your measurement with a ruler and figure out how many times you need to multiply or divide that number to reach the measurement written down on the drawing.
ordo
119'
Jan 14, 18 3:33 pm
I think you are overanalyzing the question. The dimension on the house would be 119 feet. At .25 inch = 1 foot you can just do a proportion .25 inches is to 1 foot as X inches is to 119 feet . X would be 29.75 inches which would be the length of the line on your drawing marked 119 feet.
If you wanted to convert everything to inches the answer is the same:
.25 inch is to 12 inches as x inches is to (119 feet times 12 inches)
Jan 14, 18 4:46 pm
ordo
I posted part of the blueprint, it's not very clear but it's the best I can do for now.
ordo
You're saying that what ever number written down is actual dimensions?
Yes.
ordo
Perfect that's what I wanted to make sure! Apparently Non Sequitur disagrees...
ordo
@Non Sequitur
Jan 14, 18 4:46 pm
Yes? My math was bullet proof. I can’t believe you don’t know how to multiply scales. It’s so simple and it’s the reason my Pii exists.
ordo
Apparently not.
ordo
According to Volunteer it's actually 119 ft. I know as a fact it's not a 10 ft long house...
Please, volounteer rounded up. That’s not how the real world works. I guess it’s to much to expect you know this since you’re crowd sourcing grade 2 math questions.
ordo
Because building a 10 ft house makes total sense right?
Is that a serious question? Maybe your father has another, more capable offsprings to handle this construction project.
jla-x
It's probably a small house for his mistress.
ordo
jla-x At least you make sense lol
jla-x
Noray,
Not to muddy the waters any more but 119' is a large dimension for an average house. Is there any chance the dimension is 11' 9'' (eleven feet, nine inches) which would be a common dimension for a small bedroom? How long on the drawing was the line marked 119'. If the line you read as 119' is 2.93 inches on the drawing the dimension is most likely 11' 9".
Jan 14, 18 5:56 pm
ordo
I never said it was an average house. I'll post the whole line, I just don't want to post the whole page. I don't want someone taking the design.
So you’re worried someone will steal the “design” from one page? Not going to happen, plus I’m sure you’ve just stolen it from someone else anyways.
ordo
You should change your career lol....
No need. I at least know how to read drawings.
ordo
Its forsure 119'. Its written as 119'-0"
ordo
@Volunteer
Those two tips you see are supposed to be car garages and I think is 3 cars per garage.
Jan 14, 18 6:10 pm
How old is that page?
ordo
Old enough
I can't read the line dimensions but the last line visible on the drawing certainly seems longer than 11 feet, 9 inches, so disregard what I said.
So you’ve stolen the design and are trying, poorly, to build it without paying real professionals. Classy.
ordo
So if this house was built and I were to use a tape measure it would be 119' ?
It depends on the tape. I don’t think I’ve seen a 120’ long tape thou, so maybe buy several and string them up together.
ordo
So you build houses but never been to home depot haha
I don’t build, I design and oversee construction. I can also read drawings. All 3 things you are useless at. Enjoy the doll house.
ordo
You oversee construction but don't know the existence of the working tools haha....
ordo
Maybe I'll hire you to build a tree house or something, hopefully you can get it done
Says the wanker stealing building plans but is so incompetent they need to beg strangers online for help.
ordo
At least some strangers know their working tools
you did not know how to read a scale.
ordo
I'm not an architect...
We know Nick, you're a simple mall cop.
ordo
And a simple mall cop can afford a home like this while you didn't even know a long tape measure existed hahhaaha
Not sure why you're so hung-up on that tape thing... they go up to 40' for the belt clip ones.... and then it's the long wind-up rope for excess of 100'. I don't swing a hammer for a living, I tell the grunts who do where to swing. Big difference. Anyone can afford a house if you can all the corners and avoid paying fees to professionals. It helps when daddy buys the land too... You should have stayed in school longer, perhaps you'd be a real cop today.
ordo
I'm glad you know how to use Google! Glad you finally discovered that there are long tape measures. What do you tell your grunts use a rock or something to nail the wood.
No, actually, I can't remember the last time I designed with wood. Hard to make high-rise buildings with simpleton methods. Anyways, props for sticking around and playing our game, but note that you're way out of your league here. Had you done some casual research in this forum prior to you illiterate question, you would understand why no one respects cheap wankers like yourself.
ordo
Haha thanks....youre the only replying you must have no friends haha. But when you're done with your high rise building let me know if the property owner wants any mall cop services I'll give him a great rate lol
Thanks for the offer, but I prefer that the security we hire have at least a middle-school level education.
ordo
Maybe this is more clear
Jan 14, 18 6:27 pm
who did you steal these from again?
119' = 119'
You're welcome. Please send the check to the address in my bio.
Jan 14, 18 6:40 pm
ordo
Thank You! I'll leave the amount part blank
threadkilla
Wow. So your dad has enough "sense" and resources to build a massive house that he's going to fill with 6 cars, but can't educate you well enough to carry out basic multiplication, let alone entrust this project to a qualified professional? I'm with Non on this one, you're way the fuck out of your element
Jan 14, 18 8:43 pm
Careful... he's an officer... albeit, a mall rental pilon, but still, probably caries a gun. 8-)
threadkilla
He's a fucking dolt who can't tell a bay window from a three car garage
I think we've thoroughly established that
ordo
It's very interesting how some members here have to try to belittle people here. I don't understand your people's thought process, does it make you feel better about yourselves? What is it? I'm not an architect nor was my father. Obviously, I'm not going to build the house physically a construction company is. I just wanted to know how to read and understand the measurements to get an idea of how large the house is going to be.
threadkilla
I'll entertain you, ok? Here's my thought process: I come here for entertainment such as hoping to guess a building by it's floor plan, that another intelligent and educated person, passionate about architecture has selected as a challenge for this community. I deal with all sorts of real work in real life, and in my experience the people who act in the manner you have elected to carry yourself on here are the worst. You want to do it yourself and save a buck, until you fuck up royally, and either blame it on me or call me to fix it. Hire a local professional to consult/educate you on how to build your cheapskate McMansion, don't expect anybody to solve your very real problems for free on the internet.
threadkilla
If your father designed this house, and you want to honour his memory by getting it realised - that's great! Enroll in a building code or drafting class at your local community college, get some learning in you and DIY the shit out of your dreams. Or skip the hard work, but pay for someone to do it. Not really any in-between options here
ordo
Let me entertain you now. I have no interest to be an architect nor do I care about all the little details on the print. I don't have any architect friends to ask my question. Why would I waste a professionals time to arrange an appointment just so they can tell me its 119 ft? I asked the question in a decent manner, yet you decided to belittle me and my father. If I am trying to find out the size of the house you should have figured out that something is not quite right with my father for me to just ask him. He passed away and didn't get the opportunity to ask. like I mentioned before, I don't care how it is built, what materials are needed, or what it cost. I'm going to give this to a construction company ask them when it will be ready and going to return to my property once the construction is complete. I needed to know how to understand the measurement so I can have an idea of how large the home is. So I don't understand why you I'm trying to save a buck....
threadkilla
Because myself and others on these forums do this for a living, yet you expect us to do it for ----- free. Can you do that math? It's not a waste of a professional's time to help you with all sorts of issues, including how to read your drawings - if you remunerate them for thw efforts, it's called work, guy.
Your contractor can tell you how big things are on the drawings, if they can't you shouldn't hire them.
ordo
If I had a contractor maybe I would have... So you tell people what the little numbers mean for a living? I doubt it. From my understanding, you're also an architect, so you get paid to draft/design a plan. I never asked anyone here to do that for me... Finally, not everything is about money. If someone asked me a question and I had the knowledge to answer it I wouldn't belittle and insult them I would answer it.
Hey Nick, you're the one who came into our bar and changed our sweet sweet Neil Young Jam to some cheesy pop country tunes and demanded all Tvs play the cricket match. That's why no one here cares to answer your question. You've asked for free work, something many of us here, myself included, make a living doing. No wonder no one here wants to help. Had you for example posted the entire plan and asked questions from a historical perspective, you would have at least sparked a few of our interests. This is what I suspect Volunteer was trying to get to through asking for a better picture. The snark you received is entirely merited. Now go back to your mall cop job and hire people if you want this project done right. You're clearly not up for the challenge.
ordo
I actually walked into a bar and asked to the bartender why aged brandy is better, while a drunk in the bar started tell his life story because he has nothing better to do. So when I hire someone I'll make sure it's an architect that knows long tape measures exist..
threadkilla
you 'walked into a bar' and started asking everyone there your pant size based on the number of holes in your belt. (that's how scale relations work)
tintt
116'
Jan 15, 18 12:13 am
ordo
how did you get that? I thought we established that it was 119'
threadkilla
threadkilla
How deep is a hole?
what about a half-hole? or quarter-hole?
What's the scale of the hole?
tintt
I mean 611 feet.
AdrianFGA
@ ordo
Your answer is 29.75". Positive Pete gave the short answer - 119 * 1/4. If 1/4" (drawing) is equivalent to 1' (real size), then 119' will show as 119 * 1/4 =  29.75".
Not being familiar with imperial scaling, from my metric/decimal viewpoint, I would find the decimal scale of 12 / 0.25 = 48, or 1:48.  36271.2 mm (119') / 48 = 755.65 mm (29.75") on your drawing. For double-checking, if you use a common metric scale (300 mm long) that's roughly 2.5 scales long.
Jan 15, 18 11:20 am
"By 2500 BCE, the “royal cubit” in Egypt was determined by the forearm length of the Pharaoh and carved into black marble. It was approximately 52 cm in length (20.5 in) and was further divided into 28 equal segments, approximating the width of a finger. This provided a baseline for others and consistency across the kingdom." wiki
Bring back the cubit! Good enough for the 'Gyptians, good enough for everyone.
Jan 15, 18 12:33 pm
threadkilla
If 'mercans were to rely on Trump's hand size for dimensioning things, global material consumption would be reduced drastically... Allegedly
AdrianFGA
That cubit can be seen at the Louvre
MDWed
Ah yes, wiki…
Common cubit [forearm] = 6 palms [24 digits]
Royal cubit [forearm + palm] = 7 palms [28 digits]
MDWed
JeromeS
I was wondering how long it would take to get to the answer "48".  That concepts is far beyond the OPs capacity for understanding.
How big IS 119'?  Also, how big is the OPs property?  What's scale per acre?
Jan 15, 18 12:56 pm
threadkilla
the answer to everything is 42
Almosthip7
The drawings state that the scale is 1/4 inch equals 1 foot. Using your architect scale, select the face of the tool with the 1/4 mark in the upper left-hand corner. Lay the “0” point at the extreme left end of this line, and read the corresponding value at the right end of the line.
Jan 15, 18 4:58 pm
icksdeh
This is hilarious. Just use the metric system and this discussion wouldn't even exist.
Jan 15, 18 8:33 pm
Steeplechase
The metric system doesn’t fix illiteracy.
Kevcas94
I am bidding a large project. The scale for the plan is 1/4”=1’
The problem is when I measure a measurement on the plan (for example, 5’-7”) the scale itself reads 4‘-6”.
Any suggestions guys?
Dec 13, 18 2:06 pm
General note no.1: Do not scale the drawings
General note no. 2: See General note no. 1
Besides the obvious General Note no 3 : See general notes 1 and 2. Have you measure other dimensions in the plan? Maybe printed at whatever size comes out of the printer?
General note no.4: When in doubt, ask for fucking clarification
geezertect
You obviously have a reduction of a quarter inch plan. If something is supposed to be 5'-7" but only scales 4'-6", then you will have to take all of your scaled distances and multiply by a ratio of 67/54.  Or you could get a correct set of drawings, but that might be too easy.
This glorious thread was thankfully resurrected.  I just re-read it top to bottom... and it's just great.  I wonder if the mall-cop OP ever figured out how to measure.
Dec 13, 18 2:53 pm
geezertect
It's an Abbott and Costello routine.
stevenpagan
476 feet actual size of house
Dec 25, 18 3:58 pm
