What kind of solution can I apply to Corten steel in interior use?
Duchess
Evening folks.
Im trying to figure out what kind of chemical solution can I apply to Corten steel for interior use, that it can be touched but the rust doesn't fall off.
May 10, 17 2:48 pm
Janosh
An automotive clear coat or some urethanes will work. You probably want a flat overcoat or additive. You are going to need to collaborate with a finisher on the spec as I don't think anything out of the can is going to work.
May 10, 17 3:22 pm  ·
Don't forget the free tetanus shots at the building entrance.
May 10, 17 5:39 pm  ·
Tetanus doesn't come from rust, it can only harbour it after contamination. In an interior, it's not an issue.
May 10, 17 10:47 pm  ·
Rusty!
Don't use an acid drenched, rusted out garbage can as an interior finish, Christ. But if you do, cover it in asbestos for maximum assault on indoor air quality..
May 10, 17 7:28 pm  ·
brilliant
May 10, 17 9:03 pm  ·
