as in changinf form naturally as much as possible through the process of rusting.
I know metal can get rusted to the extend of getting holes in them, but am not sure in terms of changing shape
rust (in iron/steel) is the process of oxidation, this only affects the surfaces that are exposed to
1. the air (oxygen)
the rate of rusting is increased and maybe dependent on the presence of water. and is again increased if salt is introduced.
as far as changng shapes go, its just a process of the useful bit of metal getting smaller and the amount of rust (dust and flakes) getting bigger
read up on entropy
CORTEN is a material which uses the oxidation process as a positive thing, but its mainly in the surface appearance of the metal.
i'm not really a chemist.
lead is an interesting one though, and will gradually seap/slump due to gravity (as will glass)
but this is a very slow process.
if you want to mess around with metals
lead is the easiest (low melting point)
but its not rusting thats temperature
i used to make my own lead figures in my kitchen, need good ventilation though, and a mask.
but you can do it on a regular hob
and dont mix it with your food!
Jan 29, 05 4:08 pm ·
deforming metal
is it possible for metal to deform naturally (as in change shape) through rusting.
If so which metals do this?
deform as in simply change shape/form
or deform as in 3d sudio bendyness?
magnesium is pretty funky stuff.
not sure where you can buy it from. comes in like a flat wire coil.
if you hold a match underneath it it magically change from a solid into a plasma.
make sure you wear dark glasses and protective gloves and stand well back
JB,
as far as i know.
1. the air (oxygen)
read up on entropy
