epson 1280
melivt
is it ok to print on a paper with a good "tooth" or is this ill advised? i.e.-would it damage the printer heads.
Jan 26, 05 7:12 pm
pgb
I would assume that as long as the paper was not too thick you would be ok. I have gotten away with priting on pretty corse/ textured paper on mine. But then again, we all know what happens when we assume.
could you ask printer repair shop? or a print shop for that matter
PGB
Jan 26, 05 8:13 pm  ·
pencrush
According to the epson website you can print on paper up to .27mm thick, which I know, is useless information. I've printed on fairly heavy printmaking type paper on a 1280 with no noticeable effect. I've also printed on braille paper, and some other odd media (large manilla envelopes) and it worked fine. If you're going to print on a 300lb watercolor paper, you might run a test sheet, and then print a couple of pages on regular paper, comparing quality to an earlier print of the same item to see if it has any noticeable effect.
I think you'll be fine.
Jan 26, 05 8:34 pm  ·
bigness
tomight i tried 2 sheets of 190 grams a3 (one on top of the other) and it went in just fine. i suppose you could get even thicker stuff in.
why is my called 1290? i guess is the sase as the us'1280. anyways, you'll be fine.
Jan 26, 05 11:07 pm  ·
