Question: Partial apartment renovation in NYC. Need to determine if we are changing more than 20% of electrical. How to go about it?
Should I calculate area of work and if it is grater than 20% of total apartment square footage? Or, should I count all of the existing electrical outlets, switches, lighting fixtures, electrical panels, etc. and then to determine if we change more than 20% of those?...
I would say you could go with cost. Determine approx cost of original electrical scope for that unit, and then determine whether or not your reno is more or less than 20% of that. You may want to work backwards if you have a rough idea of how much the electrical portion of your [reno] project is.
It certainly would make sense to ask electrical engineer, if project budget would permit to hire a consultant. But we already run a risk of client reducing scope of work to changing finishes and kitchen only.
But what you have said makes perfect sense, and since we are adding just 4 new electrical outlets and 5 lighting fixtures, we are good in terms of electrical load.
Mar 3, 11 11:16 pm ·
Electrical scope of work
as long as you arent changing more than 20%, you're fine...
Use extension cords.
... ummm... this is what the question is: HOW should I determine if I am changing 20%???
Use measuring tape.
if you are changing more than 20%, you probably have to pay more $$$ in permit fees. Therefore, you are changing less than 20%
I'm with mdler, just go with 'less'
Good luck.
ask the building department how they define changes in electrical
Thank you!
