How to study for ARE 4.0 (Specifically Structural Systems)
CerebralArms
I am trying to take the ARE 4.0.
Currently, I will be taking the test for New York so therefore I can take the test before my IDP is complete. I thought I would be begin working on it as soon as possible.
I have some hand me down books from the ARE 3.0, but I can't seem to find too many things on the 4.0.
I know that the NCARB website contains guidelines and example problems, but it doesn't seem like that would be enough for me.
What resources outside the NCARB website do you suggest I look into?
Do you know of study guides that you liked, references, websites, etc.?
What has your experience with this test been?
Any other suggestions, comments, things to think about would be much
appreciated.
My goal is to simultaneously finish my IDP and Exams within the next three years. Wish me luck.
the best,
CerebralArms
Nov 17, 10 2:02 pm
gresham
www.areforum.org
is the best resource on the web.
Nov 17, 10 2:57 pm  ·
tuna
This posting is a bit old but you should check out the Center of Archecture near NYU. They have great audios and pre-record videos that you can sit through.
Jan 5, 11 11:10 pm  ·
beekay31
Here's a partial list:
Solutions: Understanding the Graphic Vignettes by Norman Dorff
Kaplan ARE 4.0 Complete Library
Ballast ARE Manual
Archiflash cards
PPI flash cards
Architects Handbook of Professional Practice, AIA Press
AIA Documents
A201 General Conditions of the Contract for Construction
B101 Standard Form of Agreement between Owner & Architect
C141 Standard Form of Agreement between Architect & Consultant
NCARB ARE 4.0 Study Aids
ARE Forum
Site Planning & Design Handbook by Thomas H. Russ
FEMA 454 Designing for Earthquakes: A Manual for Architects
Manual of Steel Construction, Load & Resistance Factor Design, AISC (aka LRFD)
Structural Steel Design, LRFD Method by Jack McCormac
Mechanical & Electrical Equipment for Buildings (MEEB) by Benjamin Stein
ANSI A117.1
ADA
Architectural Graphic Standards
Fundamentals of Building Construction: Materials & Methods by Edward Allen
International Building Code
CSI Master Format
LEED for New Construction by USGBC
Jan 6, 11 4:11 pm  ·
CrazyHouseCat
You only need Kaplan. It's not perfect or complete by any means, but you don't need to have perfect or complete knowledge to pass the ARE.
Don't over study. 2 weeks prep for each exam is plenty (even for Structural systems). Aim to gain a good understanding of the material. No need to memorize anything.
Remember it's a minimum standard. You only need to pass it, not ace it.
Good luck.
Jan 6, 11 5:46 pm  ·
damirarch
Does anyone know where if any I can buy used Kaplan ARE 4.0 Complete Library books. I don't see a point in buying a new set for $1300.
May 9, 11 6:32 pm  ·
