TOEFL
Emini
Is it worth to apply for an Ivy (M.arch) even if my toefl score is under the requirement (got 81/120 and most of Ivys require 100/120 and i'am an international student) ???????
Thx
Nov 1, 10 2:11 pm
nypencil
They need money, you should apply.
Nov 2, 10 11:46 am  ·
CMNDCTRL
actually, applications are UP right now. so i would probably work on that score. if there is a stated MINIMUM, i would stick with it because they have enough applications they will probably move your application to the automatic reject pile before they even look at the portfolio. then you are out the 80 or 90 bucks for nothing.
do you have time to retake the test? test prep is not too bad if you focus on it for a few weeks. you should be able to drastically improve a score with just a couple hours of work a night. good luck.
Nov 2, 10 12:09 pm  ·
