How to Set-Up an Eye Level Perspective View in AutoCAD 2010?
All Blacks!
Any help with this would be much appreciated.
Oct 20, 10 8:38 pm
Seeker
I haven’t done it in a while and I don’t have AutoCAD 2010 to check if it has changed, but the command used to be “dview” (type dview). Set your Camera and Target location using POints (type PO). When asked to choose a location, type “.XY” and click where you want them to be. You will be asked then to input a Z value (height). Input height values for camera and target that make sense for an eye level perspective. After that you’ll have to adjust “Distance” (that should normally be 1) and Zoom (try 30 or 35mm). You can save this as a “named view” or as a viewport on paperspace.
Oct 22, 10 6:38 pm  ·
All Blacks!
Thank you Seeker.
Oct 22, 10 6:43 pm  ·
strlt_typ
have you tried orbit?
right click to access more of the menu.
Oct 22, 10 7:37 pm  ·
TheRevitKid
Export your model and import it into Revit ;)
- Jeff
www.TheRevitKid.com
Oct 22, 10 7:40 pm  ·
vikrum
All Blacks specifically asked for "in AutoCAD 2010"!!! Not Revit........
Oct 22, 10 9:49 pm  ·
PencilPusher
yeah. . .
Bitch. :)
You just got served.
(Simply for chuckle value. No offense was intended)
Oct 23, 10 1:48 am  ·
vikrum
hey revit boy,
go answer this
link
Oct 23, 10 12:16 pm  ·
