I'm looking for a cheap (under $10/sq foot) semi-translucent panel system for a small interior office project. Some sort of plastic or polycarbonate is most likely to work, but I can't find too many options.
Any suggestions?
I just graduated a couple months ago and honestly have little knowledge of materials.
I've looked at PolyGal and other straight-forward polycarbs, but if anybody knows of a more beautiful option, it would be kind of you to share!
Corrugated plastic paneling. 16mm storm-rated paneling averages about $3.50 a square foot. You'll need a minimum of 15 fasteners per 4' by 8' sheet (spaced 18" apart). Fasteners typically run about $1.50 per point.
That's a grand total of about $3.85 a square foot.
HDPE is pretty cheap and if you get it in a 1/16th or 1/8th thick it is, "semi-translucent", appearing more or less so depending upon how it is lit and the backdrop.
for reference, last year i got a 4'x8' sheet of 1/8th" HDPE for $45 from a local supplier. It is a thermoplastic so it can be remelted many times with gradual degradation. This is important, practically, b/c it cannot be laser cut. it melts and the melted plastic runs together after the laser passes and sets right up again. It mills well though, and this is how I worked with it. I think it is a very attractive material.
As far as how translucent it is, from a distance, with nothing behind it, it just looks white. With something behind it and no strong backlighting, very strong shadows are easily visible. With strong and/or colored backlighting, color and form can be made to show through.
Sep 24, 10 11:21 pm ·
Plastic / Polycarbonate Paneling Products?
Hello,
Any suggestions?
saran wrap
What?
Oh wait, you wanted someone to name a specific product.
www.designfinder.com/ pay someone.
Or refrabricate the panels yourself. I'm sure there's some decoupage glue and some tissue paper within 10 miles of you.
