archiCAD
Apr 19 '12 8 Last Comment
reed b/w
Apr 19, 12 12:24 pm
I have used archiCAD as my primary drafting and modeling program for over three years.  I am a big fan of the program.  However, I am finding out that it may be less poular than I once thought.  Everyone's BIM default seems to be revit.
I have a basic knowledge of revit, I know enough to be dangerous.  However, I'm wondering if there are some fellow archinecters that are fluent in each program.  How similar are they?  What are each program's strengths and weaknesses comparitively.  Also, will revitt eventually make archiCAD obsolete?
Thanks
gwharton
Apr 19, 12 1:20 pm
All BIM programs have the same basic logic to them, though the command structures differ. I've used both ArchiCAD and Revit (though primarily as a design tool, since I don't do CDs), and the differences between them are sort of like the differences between Spanish and Portugese: clearly different, but similar enough that if you're fluent in one you can get by in the other without a lot of difficulty while you learn its nuances. I find them far more similar than, say, Microstation and AutoCAD, but maybe that's because I use them in a specialized way (schematic design, mostly). Actually, I'd say that Revit is more similar to ArchiCAD than it is to AutoCAD, even though it's an AutoDesk (spits on ground) product.
holz.box
Apr 19, 12 1:41 pm
we're in same boat as gwharton. eventually, even revit will become obsolete. but if you are comfortable working in archicad, it's not going anywhere for a long time. it's a lot more common in europe (along w/ vectorworks).
Xenakis
Apr 19, 12 2:45 pm
Holz.box - this begs the question - whats over the horizon that's going to replace Revit? - just researching this issue now to avoid ending up - "Well Tuck looks like we gotta let ya go this new ZYZ software is way over head my friend"
holz.box
Apr 19, 12 3:04 pm
i don't know - i just know that eventually, like all software, it will eventually be replaced by something better.
i imagine it will be replaced by some uber-connected, uber software that is not just utilized for all phases of design and evaluation, but construction management and building lifecycle management as well.
A WA W
Apr 19, 12 3:18 pm
I used to use Archicad. Sold my license a few years back to an architect in Ireland. It's a great program but the network here in the USA is too small to leverage into any competitive advantages.
gwharton
Apr 20, 12 4:52 pm
As for replacements for Revit, has anybody noticed how Google is slowly revamping Sketchup to move into parametric modeling? A quasi-parametric Sketchup would be a true Revit-killer.
Xenakis
Apr 20, 12 5:47 pm
gwharton - just as i suspected - 2 months ago, they had an add for Architects with 1 - 3 years exp with Revit and sketchup - then again they could have been doing another routine TI to the Googleplex in Mountain View,Ca
jcr
Apr 20, 12 9:41 pm
There is an extensive discussion on LINKEDIN, ArchiCAD Group, ArchiCAD vs. Revit. It will help you understand the pros & cons. It is more difficult to find work (in the U.S.) when your expertise is in ArchiCAD but if you find a job you want that uses ArchiCAD initially you will have a huge advantage, Good luck!
Please wait... loading
