I have to re-format my compuer soon so I'm wondering if I should re-install Vista or install Windows 7.I have Adobe CS 3,Autocad 2007 and Rhino 4.I'm fed up with Vista but I don't want to deal with compatibility issues after I install Windows 7.Can I use these programs on 7? What do you recommend?
I haven't upgraded past the initial CS3 version. And if you are having problems with compatibility you can still attempt a workaround in windows 7 home premium by running the program as administrator and other weird-ities.
Jun 28, 10 4:10 pm ·
Software compatibility with Windows 7.
All I can say is I'm running rhino, autocad 2009, the CS3 suite, and 3ds max 2009 on windows 7 64 bit with no issues whatsoever.
Thanks for the reply.I heard somewhere that Photoshop 10 may create problems.Did you have to upgrade CS3?
you would have to get windows 7 pro version to get the compatibility function. all of the window 7 'home' versions do not include it.
