I was challenged the other day to model a fortune cookie in Rhino with just using line and loft commands. Any suggestions?
confucius say: think backwards to make forward step
Come on you can do better than that!
lao tse say: try "sweep 2 rails" instead...
I just tried this. I have completely forgotten how to draw in rhinko now and every time I move around my view boxes flicker.
lao tse say- there is a yin and yang aspect of every line u mediate before the enlightment comes...
hahah, what a great thread.. my suggestion...just draw 5 point curve and rotate twice in the y and zloft...duh
all right lets see it! Sweep two rails?? I don't think so try again!!! ff33 might have something. Maybe...... New rule> Must post result if you post a text solution.
Does it have to hollow on the inside?
got it. 30 minutes. :D
for a down and dirty dimpled cone: pushed in circular rail line to apex sweep mirror i cant see that taking more than 60 seconds. multiple lines to apex for smoothing, still cant be more than a minute. down n dirty for elegance, perhaps 30 min.
simply mirroring it won't give you the right connections. mine is a single surface.
Mmmmm....cookie.
yes hollow inside. After all , where would you place the fortune?. Evan not bad ! but , a little crinkle in the center. Should be a a simple fast. Pretty close .
Evan , What steps did you take?
the crinkle makes it more realistic! here are the input curves, and what it looks like if i left loft on 'do not simplify'. the image above was done w/ loft set to rebuild w/ 20 pts.
So far I think Evan is the winner unless . Someone else comes delivers something better!
do you have a cleaner strategy? (one problem w/ mine is the central spine is still a loop - so there's a small hole there that shouldn't be). this was fun.
I will post in a couple days . Just wanted to give others a chance first.
oops, sorry did not mean to do that.
You can do it in about 3 minutes with a sweep1. But I guess that's no fun?
you could also take a circular planar surface and fold it up with cageedit in about a minute... but that's cheating.
::slaps forehead:: after thinking about this all day, i finally got it. so easy.
what's next? BRING IT ON!
That"s it you did it!!!!!!!!!!!!!!!!!!! Congrats!!!!!!!!!!! We have a winner!!!!!!!! ha,ha, lol
it's the next serpentine pavilion. genius
How quickly can anyone model a rhino, in Rhino?
Haha Great looking fortune cookie Evan.
Model a Fortune Cookie, Fast in Rhino?
Any suggestions?
line to apex
sweep
mirror
down n dirty
Mmmmm....cookie.
Pretty close .
this was fun.
::slaps forehead::
