Survey about modern architecture
Maudite
I'm a student at the Boston Architectural College and I've put together a survey that investigates attitudes about modern architecture.
Please try it out. If you find it interesting, pass it along to anyone else you might think would be interested. The more responses, the more varied the respondents will be and the more compelling the results.
Here is the link:
http://www.surveymonkey.com/s.aspx?sm=HqUy1L9i6WPOZJ67R6xASw_3d_3d
Nov 19, 08 10:31 am
bravo_on_trace
Do we get to know the results?
Nov 19, 08 11:52 am  ·
Maudite,
I'm always interested in research, and popular attitudes toward architectural styles is a fascinating topic for me. That said, the (mostly) repetitive list of somewhat strange adjectives kept me from continuing past the tenth image or so, and I exited. I could only check "straightforward" so many times, and none of the other descriptors made sense to me.
If your research is still in the design stage, maybe consider a wider range of terms? Or a scaled response (1-5, or 1-10) to positive or negative (or other, more specific) assocations, perhaps?
Best of luck, regardless.
Nov 19, 08 12:04 pm  ·
won and done williams
yeah, the adjectives aren't working for me. i'm too familiar with these buildings for any of your adjectives to express my feelings towards them. calling crown hall "sophisticated" is a little weird, but none of the other adjectives made any more sense. i think citizen's scaled response idea might produce better results.
Nov 19, 08 12:31 pm  ·
207moak
I third the comments above
Nov 19, 08 1:04 pm  ·
kungapa
Either a quantitative scaling, or a blank field where you can enter your own response if qualitative scaling is really what you are after.
If you get enough responses you could perhaps make a wordcloud out of the entries.
Nov 19, 08 1:16 pm  ·
LB_Architects
Agree with the above posts. I stopped after 4 images. Horrible adjectives and they keep switching places from one image to another. Way too time consuming to participate.
Nov 19, 08 1:22 pm  ·
brian buchalski
probably having the words "greatbuildingsonline" in the corner of half the pictures is not a good idea either. an architect would probably ignore it, but a lay person might use that as a clue to how they should vote rather than how they would vote
Nov 19, 08 1:28 pm  ·
leave it to architects to redesign the survey instead of answering the questions. not that it's not warranted, but...
Nov 19, 08 2:18 pm  ·
What's the problem?
Aggressive, stark and awkward were the only words I needed!
Villa Savoye did look precise though.
Nov 19, 08 3:42 pm  ·
Apurimac
funny, I called it precise too.
You're adjectives don't work at all, I'd prefer: Really like, like, no opinion, dislike, really dislike.
Oh, btw, only an architecture student/teacher would use the word "idiosyncratic" on an online survey. If you're aiming this toward the general population that's not a word to use.
Nov 19, 08 4:00 pm  ·
MArch n' unemployed
i've never heard a building referred to as dowdy - a grandmother maybe
Nov 19, 08 4:06 pm  ·
I used dowdy once, the AEG factory.
That roofline reminds me of a Babuschka.
Nov 19, 08 4:55 pm  ·
Maudite
Thanks for the feedback; I now realize it takes longer than I expected to (and requires more patience) to get through than I had intended. I changed the settings so that you can leave and come back as long as you are at the same computer--if any of you want to finish.
I'll be posting results in about 3 weeks.
Nov 20, 08 11:12 am  ·
Maudite
Thanks, everyone. The survey is now closed.
Dec 3, 08 11:09 pm  ·
