revit column extrusion
strongcophee
first time revit user, how do you extend/expand a column in revit?
Sep 30, 08 8:42 pm
check the element properties.
Sep 30, 08 10:10 pm  ·
gonad
you will have to edit the family to make the column a particular size.
adjust the height in the elements properties
Sep 30, 08 10:22 pm  ·
typically revit comes with a default library of nearly all the steel shapes, so changing flanges or web thicknesses should not be needed.
Sep 30, 08 10:28 pm  ·
Benjamin_
The help function is surprising.......helpful in Revit. I learned almost everything I know in Revit just by screwing around and when I got stuck, I went to the help menu.
Oct 1, 08 8:15 am  ·
