Could you not use e.g. rhinoscripts of which there are plenty around and export the outcome into catia/dp? Or write your own, there should be some tutorials around where you found some scripts in the first place. I'm always kind of skeptical about using scripts I don't really understand. Well good luck and let us know how it's going.
In this CATIA / Digital Project video will use an Ordered Geometrical Set with nested Bodies to define a PowerCopy. We will then use the PowerCopy Instantiator by Geometrical Sets script to automate the instantiation of the PowerCopy. Finally, we will delete elements, make updates to the model and re-run the script to update our model based on additional inputs.
Thanks a lot,
Tony
Oct 18, 12 4:59 pm ·
Digital Project/Catia Scripts
Does anyone have any good sites with CATVBA scripts? I have found some ok examples but they seem to be few and far between.
Seeing that the thread is not really taking of...
What kind of scripts are you looking for?
did you check on GTwiki.org?
Fred
Thanks a lot,
Tony
