Rhino Command Options
induct
So this is a ridiculous question but I find that when I learn programs by messing with them I miss a bunch of basic stuff. Anyways.
I need to extrude a whole lot of buildings in a city. So I am extruding the curves as surfaces straight. But every time I extrude one I have to change the option from Cap=no to Cap=yes. How do I set it to yes permanently so I don't have to do it every time?
May 6, 08 12:27 am
garpike
It should be yes by default. Are you using 3 or 4?
May 6, 08 12:28 am  ·
Jayness
You could just extrude your curves as a solid rather than a surface
May 6, 08 12:38 am  ·
induct
Using 4. I don't know the default is no. Is creating scheme the easiest way, seems somewhat ridiculous.
As far as using solids over extruded surfaces what is the end difference?
May 6, 08 12:44 am  ·
MArch n' unemployed
you can very quickly select all of those extrusions and then type 'cap'
May 6, 08 2:24 am  ·
garpike
Will cap work if open on bot ends? I haven't tried 4 yet.
May 6, 08 2:57 am  ·
garpike
[i]both/i] ends...
May 6, 08 2:57 am  ·
garpike
Ah turds you know what I mean.
May 6, 08 2:57 am  ·
Antisthenes
use the solid command "extrude solid from planar curve" not the surface command
that will auto cap anything it makes, this solid
May 6, 08 1:55 pm  ·
difficultfix
if you use the toolbars,
surface toolbar has extrude straight, while the solid toolbar has extrude closed planar curve.
you could create a custom toolbar where you could place the tools you prefer
May 7, 08 2:31 am  ·
FOG Lite
greebles....
May 7, 08 10:26 am  ·
Antisthenes
as in....
2. greeble
20 thumbs up
Random bumps, extrusions, and hills and valleys, usually planar. Used in 3D modeling and animation to add interesting detail, like that on the surface of the DeathStar.
"Yo dog, that greeble modifier really pimped out your 3D model."
May 7, 08 1:10 pm  ·
