Hi, When I render out of Rhino into Maxwell, the command bar reads: "object reference not set to instance of an object", my file crashes and an error reporting box opens. I think it is something in the drawing- but i don't know-- Thanks
Are you using the most up-to-date version of the plugin and MXCL? It seems like you have blocks that are behaving badly--try "exploding" the blocks to see if the problem is fixed. Also, make sure to fill-in and submit the error report; JD uses the responses for troubleshooting and is pretty responsive to user feedback.
Maxwell problem..
Hi,
Thanks
