Does anyone know of a way to import Light and material settings from one maxwell file into another?
I have three conceptual schemes, all the same shot, materials, lighting, etc... Is there any way to avoid having to reassign all settings from scratch with each scheme?
Thanks In Advance!
are you using maxwell studio or are you using maxwell through a 3d program like rhino? if its the latter i would have done my 3 schemes in the same file, on different layers then set up your lights and materials and render each scheme with the others turned off.
MAXWELL RENDER HELP
Thanks In Advance!
save(export) your materials to your hard drive…
