I have a few camera views set up, which were previously working fine. Suddenly ( I must have clicked some setting), my camera views are cutting the model as if it were cutting a section. Does anyone know how to fix this? Thanks!
this is a known issue--make sure that you have all extraneous text, points and lines deleted, especially if they are far from the origin
I thought it was another case of OE but I guess its not. I'll try to clean up the file some and see what happens. thanks.
YES!!!! I deleted the curves and the problem was immediately fixed. Thank you.
Rhino camera
