flattening an autocad 2008 drawing
cowgill
i know this has been covered before on earlier versions of Autocad but i can't get those solutions to work on Acad Arch 2008.
... running the lisp command may work but i don't know how the hell to do that
prost!
* i don't have express tools
Mar 26, 08 10:31 pm
lletdownl
have you tried 'overkill' ?
Mar 26, 08 10:45 pm  ·
lletdownl
dont know if that works in 08...
lletdownl
oh and im guessing your not talking about getting rid of extraneous lines either...
great work me...
Mar 26, 08 10:46 pm  ·
Workshop B
type in the command flatten, select what you want to flatten...
Mar 27, 08 1:17 am  ·
xacto
hey...sorry dont have an answer about Acad Arch...in my experience i have found that it behaves differently sometimes than just regular acad. i dont think i could use overkill, and not sure about flatten.
good luck.
Mar 27, 08 3:49 am  ·
cowgill
thanks for the replies but neither "overkill" or "flatten" work ~ bollocks!
any other suggestions?
Mar 27, 08 7:25 am  ·
Liebchen
Flatten works for me.
Mar 27, 08 11:20 am  ·
Liebchen
If flatten doesn't work, can you do some creative file format changes? Example: print top view to PDF, open in Illustrator, export to a .dwg, then re-open in AutoCAD?
Mar 27, 08 11:26 am  ·
rehiggins
the current version of "flatten" (in the express tools) seems to be a slightly tweaked version of the old LISP routine. It appears to be used to make 2D versions of 3D elements whereas the old version took all z-values and made them zero--the new one doesn't work well if you have coplanar linework at a z-value other than 0; it also appears to be view-dependent (like Rhino).
Anyone have the old version (R2000)?? I've unfortunately lost mine and it was quite a handy little tool…especially when cleaning up someone else's sloppy drafting.
Mar 27, 08 11:44 am  ·
Antisthenes
" MAKE2D " in Rhinoceros works for my stuff that i get in autocad format if that helps
Mar 27, 08 12:31 pm  ·
gonad
i can send it. whats your email addy?
Mar 28, 08 3:44 pm  ·
gonad
and by that, i mean i can send the old lisp :)
Mar 28, 08 11:40 pm  ·
monkeyboy
Open in Rhino, Project to CPlane one layer's contents at a time. Save as dwg and reopen in autocad
Mar 30, 08 11:09 pm  ·
cowgill
thanks for the replies.
I'm downloading and installing the Rhino demo now.
Mar 31, 08 6:15 am  ·
