Do you need a 24x36 image at 300dpi??? It's a bit ridiculous to waste the time rendering something that big (unless there's a good reason of course)--if you do eventually accomplish the render, are you going to be able to print it out (without having to downsample)? The file size is going to be on the large side…
My bet is that the hardware you're running on is not even remotely up to the task of an image that big, nevermind the fact that you're probably hitting a built in limit with Flamingo.
hopefully you've done test renders at a smaller scale and have all the materials/lighting/camera/model kinks worked out, it would really suck to do a 'hero' render like that and have bad tiling or inverted normals or ?
c) is the correct answer. Flamingo is WAAAY slow compared to Vray and gives a poorer result to boot.
I've never needed anything in excess of 5000xX, even for construction fence signage. Try and talk whomever is asking you for this size down, resolution is dependent on viewing distance after all.
Rendering Large Scale In Flamingo
Anyone have any advice on rendering massive images in Flamingo
I'm looking to generate an image that's 7200px x 10400px....
I know...huge
it crashes when i spec this size....is there a way to render this size? in pieces perhaps?
any advice would be appreciated.
um, silly question, but why so big?
Couple choices:
a) reduce the size
b) new hardware (RAM, RAM and more RAM and a faster hard drive and multi-core processors)
c) use something other than flamingo
unless it is flamingo2/accurender4 ya Vray Brazil or Maxwell
