illustrator to open dwg file (again)
aspect
i'm using illustrator to open .dwg file, however, some .dwg file i can open but some cannot...
any reason why?? version problem?? any setting i should adjust at autocad inorder to be able to open at illustrator?
thanks.
Jan 23, 08 10:03 pm
aspect
i tried to export to bitmap but the quality is not as good as illustrator openning a .dwg file...
anyway, my goal is to have the .dwg drawing transfer to a nice line drawing in tiff.
thanks.
Jan 23, 08 10:06 pm  ·
joshuacarrell
I have illustrator cs3 and it only accepts dwg pre acad2006. I usually save back to 2000 just to be safe.
j
Jan 23, 08 11:16 pm  ·
xacto
try printing to pdf.
Jan 23, 08 11:22 pm  ·
aspect
great thanks! try printing to pdf, it works!
Jan 23, 08 11:51 pm  ·
induct
CS3 and dwgs don't work together very well, Adobe took out most of the compatibility that was in CS2 because they said it was erratic.
But that said they are developing a plugin now that should import layers and everything.
Jan 31, 08 11:48 pm  ·
Antisthenes
why not use rhino and do a -viewportcapturetofile (tiff) at very high res.
Feb 25, 09 11:16 am  ·
cowgill
using CS2, I save the .dwg as a 2004 and it works fine.
Feb 25, 09 11:40 am  ·
MArch n' unemployed
if you have rhino open the .dwg there and then export it directly as an .ai - forget this opening stuff
Feb 25, 09 12:16 pm  ·
Antisthenes
if you want line weights/types turn on PrintDisplay and print to Tiff/png/bmp
Feb 25, 09 1:10 pm  ·
Piacquadio
you can print the dwg in PDF with autocad and open this with illustrator !!!  there are a problem: when you print in PDF the layer deletes ! i advise you to apply the different colour to different layer. with illustrator you can select lines of the same colore together, you can make the group of line and move this in other layer....!!!! i hope you have been helpful ;)
Dec 11, 13 6:13 am  ·
