Foam Cushion cutting and order Fulfillment
deforestm
I'm in LA.  I'm looking for a 3D laser mold cutter that can cut curves around a piece of high density foam cushion.  And then a distributor for fulfillment orders.
Mar 30, 13 6:47 pm
Thecyclist
I've not heard of a 3d laser cutter
Mar 30, 13 7:48 pm  ·
accesskb
lol i think you need to invent a 3D laser mold cutter first
Mar 30, 13 8:27 pm  ·
deforestm
Learning is an on going process.
http://www.3dcutting.com/solutions/frogmill.html
Mar 30, 13 8:34 pm  ·
accesskb
its a CNC machine :)
Mar 30, 13 8:51 pm  ·
LITS4FormZ
Pretty sure Sci-Arc, UCLA and USC have 6/7-axis machines that can do this
Mar 30, 13 9:05 pm  ·
deforestm
Apr 2, 13 7:00 pm  ·
I worked in furniture manufacturing in the early 2000s and we built chairs ( I worked on the assembly line) for the Athens Olympics and other huge sporting venues, the tool we used and they still use to carve foam rubber for cushions is an electric carving knife.
https://www.amazon.com/BLACK-DECKER-Electric-Carving-EK500B/dp/B01K1JJAI2
Irwin seating can probably fulfill this order. but if it is less than 1000 pieces you might be better off doing it yourself
https://www.irwinseating.com/
Over and OUT
Peter N
Jul 23, 20 9:36 am  ·
I don't believe foam is safe to cut with a laser.
Jul 23, 20 12:31 pm  ·
