problem opening reference drawings
meow
I'm having an issue opening up referenced files when I have drawings already opened with a file referenced into it. For example, I have a sheet of elevations already open, if I try to open the separate elevation reference file, cad displays a message that the file is already in use. I imagine it’s a simple command line option, but any help would be much appreciated.
Dec 26, 07 9:58 am
EdgewoodAnimal
Go to Tools -> Options -> Open and Save tab
On the external references section make sure that 'enable with copy' is selected.
Sounds like this might be the issue
Dec 26, 07 10:14 am  ·
meow
thanks, edgewood animal, thats seemed to do the trick, ive been having this problem for a while
Dec 26, 07 10:26 am  ·
