CONVERTING CAD FILES
skilla
Hi everyone
What is a good software or program to convert CAD drawings in a JPEG or PNG file with good resolution, that I can put it in Photoshop to do some rendering work on it?
Oct 11, 07 2:04 pm
holz.box
ack.
illustrator illustrator!
Oct 11, 07 2:07 pm  ·
AbrahamNR
You can make CAD files into PDF's directly from cad if you have Acrobat Installed. Just select Adobe PDF as your plotter and plot to file (play with the settigns so you have a large resolution on that PDF). Then you can open that PDF in Photoshop and render away. That's how I did it in school.
Oct 11, 07 2:23 pm  ·
skilla
o ok sounds good I will try it out! Thanks
Oct 11, 07 2:28 pm  ·
Antisthenes
open your cad file in Rhinoceros and:
" -ScreenCaptureToFile"
and you can pick your resolution (300 x 8.5 = 1650 for example)
Oct 11, 07 4:27 pm  ·
Antisthenes
& if you need print display use the "PrintDisplay" command.
Oct 11, 07 4:28 pm  ·
skilla
I see.......ok!
Oct 11, 07 4:47 pm  ·
pvbeeber
You can also set up an eps driver in CAD. This will allow you to "print" to a vector file (.eps) which you can then open as a raster image at any resolution in Photoshop. No special software, drivers, etc. needed.
Oct 11, 07 5:38 pm  ·
skilla
O ok you guy have been a great help thanks!
Oct 11, 07 5:51 pm  ·
