foamcore joints
joe
what is the tool called that cuts the end of foamcore so you can cleanly butt it together without the foam showing?
I've seen them, but I dont know where to start. I'm trying to pick one up for the office.
Jun 14, 07 3:35 pm
FRO
it's called a rabbet cutter
Jun 14, 07 3:46 pm  ·
cadalyst
ive seen a mat-board cutter, but never a foamcore cutter. i think i might have to buy one:
http://www.artstuff.net/rabbet_cutter.htm
Jun 14, 07 4:01 pm  ·
snooker
I thought someone had gone over the edge and was smoking foam core to get high.....whew!
Jun 14, 07 4:23 pm  ·
joe
thanks guys.
Jun 14, 07 4:37 pm  ·
cln1
no special tool required:
just measure the thickness of the foamcore and create your own joint - dont cut all the way through, peel away paper from one side + foam and glue your joint (but place glue on the foam on the inside corner of your cut and not the remaining paper, or it will be sloppy)
time per joint: 30 seconds
Jun 14, 07 4:51 pm  ·
mdler
these joints work better on the black or off white foamcore with the paper backing. If you use the white stuff with the shiny surface, you have a greater chance on your blade slipping...also, the black or off white foam core tends to warp less
Jun 14, 07 5:10 pm  ·
binary
foam core sucks.......
Jun 14, 07 5:35 pm  ·
I'm with cln1 and b here keep it old school. no one really needs a rabbit cutter
Jun 14, 07 9:38 pm  ·
AP
you really shouldn't smoke that stuff.
Jun 15, 07 9:52 am  ·
