Calculating FAR question
- double checking some FAR calcs and having issues.
would Anyone know where I look to find the proper FAR calc procedure ? ( for DC )
is it in the building code ? Zoning ?
better yet, maybe you just happen to know where  I should look to see if HVAC and other penetrations are included in the gross area calculation for Ground Floor , while excluded from upper floors ?
Jul 30, 12 6:57 pm
el jeffe
dunno about DC, but i've not seen a FAR calc that is more fine-grained than gross building area divided by lot area.
FAR is only used with regard to zoning, so i'd look in your zoning code.
Jul 30, 12 7:28 pm  ·
c
thanks - found it .
I guess i misstated my question. it was really about what counts and what doesn't count in gross floor area ( in code )
seems that all vertical penetrations are excluded from gross floor area. even tho some other folks here thought that ground floor penetrations were included.....
Jul 31, 12 5:28 pm  ·
