Does anyone know the protocall for bringing a sketch up model into revit
-ive tried to "create mass" and then import a a "CAD format" then select the sketch up file...but then revit crashes
- i dont know if this is the way most users do this, but this is what ive tried
You're doing it the right way, I think. I've done it before successfully, but I'm trying to remember how. You need to do it under Create Mass or Create Family and it comes in as a family. Maybe your sketchUp file is too confusing for Revit?
Oh, also...you need Revit 9 or newer to do it. It's only since last summer that you've been able to import SketchUp into Revit, so if you're working with 8.1 or something, it won't work.
nothin' - what a bummer - tried a number of tutorials and websites...but nothin'...is everyone sure they dont know how to do this...come on - i know you archinectors can pull something like this off!
I've been having the same problem...Revit crashes as soon as I try to import the Sketchup model. The problem seemed to be an incompatibility between Revit 9.1 and Sketchup version 6. If I saved the SU file down to v5, it imported flawlessly.
yeah that worked but for only a real generic model - the more detailed model i tried to insert wouldnt insert b/c some objects could not imported - Revit said
"Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport."
what the hell is a polymesh object? i searched acad and found nothing. and revits help is a whole new jargon for me so ?????????????????????????????????????????????????????????????
sketch-up to revit
for autocad, i've always done it from sketchup: export a dwg. then revit can import a dwg. mabye???
Check out the video tutorial.
http://revitrocks.blogspot.com/2006/09/sketchup-with-your-revit.html
http://www.cadclips.com/Revit9-Detailing.asp
using 9.1
thanks ill check out those links when i get to work
ive herd there is some sort of plug-in for revit...anyone ever here of that
huh! - ill have to try that tomorrow...thanks!!!
link do not import, just link:
Make sure
all layers are as one
everything is white
sketchup is saved as v8 or less
explode everything
polymesh as far as i can tell is accessible in revit and not sketchup. dunno y
This thread was dead for 10 years, I'm guessing they figured something out.
