Residential Elevator - Suggestions
benben
Have been dealing with institutional work most recently (hence, dealing with the "big" elevator companies) but now am looking for advice on a 2-3 stop residential style elevator. Any suggestions would be great.
Jan 2, 07 11:20 pm
dierxap
If speed isn't an issue, and cost is, consider a limited use/limited access type elevator. I believe 3 stops would be maximum with this type. No pit needed and about 45 grand for 3 stops.
Manufacturers that I know of are Orion, and Garaventa.
Those two are not pretty..just solutions.
Good luck.
Jan 3, 07 8:05 am  ·
benben
Thanks - I also discovered that Thyssen Krupp has a residential line of lifts called TK Access. http://www.tkaccess.com/residential-elevators/
Jan 3, 07 10:41 am  ·
ochona
concord from canada -- actually seen these installed. they're really not that expensive.
Jan 3, 07 10:52 am  ·
raj
most of the work using residential elevators have been in TEXAS so this site might be only good to find out who they use and find a dealor in your area.
home elevator
Jan 3, 07 10:55 am  ·
whistler
We have used concord recently on two SF homes and they were less than 30K Canadian. approx. 42" x 60" ( wheelchair size.)
Jan 3, 07 3:19 pm  ·
Sean Taylor
I've used Inclinator before. It is nice as far as residential elevators go. Able to fit it up with custom wood panels on the interior.
I want to go up
Jan 3, 07 4:41 pm  ·
