He Say...It's Ipe!
ThriftyAcres
Does anyone have any tips/suggestions/stories when using Ipe (pronounced Epay) in regards to:
Finishes (interior and exterior)
Prices
Distributers
Environmental concerns/benefits
Good examples (in your opinion)
I'm hoping to learn a little more about this wood and perhaps spec it for a residential application. How does it hold up against the elements? i.e. huge snow loads and hostile sun.
Thanks for any advice in advance.
Dec 22, 06 12:01 pm
liberty bell
e, I've been missing you so I'm calling for your help here!!!
Didn't e just do an ipe deck on his own Seattle house?
Dec 22, 06 12:12 pm  ·
mdler
dont send it through the planer at the school shop...very loud
Dec 22, 06 12:13 pm  ·
mdler
for planking on a deck, you can use 3/4" instead of 1-1/2" that you would have to use in other woods.
Dec 22, 06 12:14 pm  ·
treekiller
Ipe rocks when it comes to weathering/durability. can't be beat... difficult to fabricate- all screws need to be pre-drilled - also use a nuisence dust mask to avoid breathing in sawdust. typically left unfinished and weatheres to a elegant soft silver gray.
there is lots of illegal logging in the amazon for ipe & other hardwoods- bad, very bad!!!!! but there are plantations and managed forests that supply high quality ipe for the north american market. specify certified sustainably harvested lumber only...
All public project in NYC use ipe, the Williamsburg bridge has millions of board feet for the pedestrian walkway. Need any rougher use/environment examples? don't know about marine/submerged use, i'd only use it for wear surfaces.
most local lumber yards can supply ipe... it's fairly pricy but has excellent lifespan
Dec 22, 06 12:18 pm  ·
treekiller
use carbide tools- will dull regular steel quickly.
Dec 22, 06 12:19 pm  ·
ThriftyAcres
mdler - I can imagine any wood that is as hard as this to be extremely loud in a planer.
treekiller - thanks for the info. I found a place that claims to only sell products from sources that use selective harvesting (I think that is what it's called). His site showed him in brazil visting his source.
Dec 22, 06 12:27 pm  ·
dml955i
We use it all the time (for exterior decks, screens & fencing), usually at 5/4" thickness.
The material costs are relatively cheap, but installation costs are higher than your typical PT wood deck. Because Ipe is a very dense species of ironwood, it has to be pre-drilled for fasteners (you can't nail it) and it takes its toll on sawblades - this causes some creep in install costs, but not too much.
As for finishes, we usually spec a clear oil based sealer, but this has to be maintained regularly to preserve the deep orange/red/purple color of the wood. Allowed to weather, Ipe will take on a gray/silver color very similar to weathered cedar.
Dec 22, 06 12:28 pm  ·
ThriftyAcres
Maintained regularly? Would you say it needed to be applied every few years, every year, 6 times a year, or so many times a year you need to hire some staff...
Dec 22, 06 12:42 pm  ·
dml955i
Depends on the exposure and owner's preference. If it's getting hammered by weather and the client wants that beautiful, rich wood color, then it's a once-a-year application.
Dec 22, 06 12:45 pm  ·
207moak
We get it milled with a groove and use a blind fastener clip to avoid all the predrilling.We install it without finish - it weathers to grey eventually.
Dec 22, 06 12:54 pm  ·
Chch
That's some mighty fine detailing, thrifty!
Dec 22, 06 1:01 pm  ·
two-headed boy
The comment about ipe escalating install costs is obviously going to be more true with some contractors and less with others. I've used it as a decking and as outdoor cabinetry for barbeque areas. My experience has been mixed and always contractor dependent. At least in California, you have to find a contractor who is familiar with the product. I had one project that literally put a contractor out of business. He was on the verge before hand but he got really backwards trying to learn how to work with it.
Also, I havent seen it mentioned above, there is a wax product that should be used to coat all cuts made against the grain. This will prevent small checks from turning into huge cracks as the wood dries out. Most milled ipe will come with the ends coated in this stuff and you should coat all of the cuts made on site as well. It does age beautifully, though - silver grey like teak.
Ive used it near the ocean (not in the ocean as the photo above shows) and it seems to be fine with the salt.
Dec 22, 06 1:12 pm  ·
ThriftyAcres
Chch- not mine...but yes, it is really well done.
207moak- I've seen the 'milled with groove' stuff but i would be concerned that the wood could start to cup a bit and as the deck shrinks and moves, these wouldn't hold up. However, I've also heard that this wood doesn't shrink much because it is a hardwood?! True?
Dec 22, 06 1:36 pm  ·
meow
if it does cup a bit, just fill it with caulk, with the crew you hired to refinish the deck once a week.
Dec 22, 06 2:47 pm  ·
meow
purrrrrrrr.........................see you at the xmas party.........................purrrrrrrrrrrrrrrrr..................bring your laptop...................purrrrrrrr.........
Dec 22, 06 2:48 pm  ·
evilplatypus
Used it many times, as a carpenter. I thought it was called like Pau Lope - I know its dense as shit and its a Walnut species who's internal oils make it naturaly water repelant. You got to piolet all the holes because it is a hardwood.
A couple years ago I had to drive deep into the heart of Ind. to get it cause the place that sold in Chicago was sold out.
Dec 22, 06 3:45 pm  ·
evilplatypus
I heard it all comes through one distributer in NJ as well. Its like a monopoly on this stuff.
Dec 22, 06 3:47 pm  ·
FOG Lite
You might also look into another species called Red Balou, similar properties to Ipe but only about $1 or so a board foot. I don't know about it's environmental bona fides but it's good stuff.
Dec 23, 06 2:02 pm  ·
FOG Lite
Oh and TWP(total wood protectant) is what we used on it for a siding sealant.
Dec 23, 06 2:06 pm  ·
