autocad to maya
finB
hey guys, i am a new maya user and i was wondering how to import autocad files to maya? thanks in advance
Oct 23, 06 1:46 am
aeaa
you have to explode and purge everything and then save it off as a DXF. I think....its been a while.
Oct 23, 06 1:16 pm  ·
rehiggins
depends on which version you have--if you have 6.5 or 7.0 (pre-service pack that is) you can enable the DWG/dxf import filter.
If you have 7.01 or whatever it ended up becoming after the update, you're screwed because Autodesk removed the dwg importer with that update.
I believe 8.0 has the dwg importer back, but I haven't upgraded yet so I could be wrong.
The 7.0 bonus tools also have a 3ds importer which can come in handy as well
Oct 23, 06 5:43 pm  ·
misterTT
if you've got access, use rhino to import, and then export the file as .iges, maya likes .iges, and will treat you like a king
Oct 29, 06 1:12 am  ·
perturbanist
It may be a bit late but,...
save as dxf - & file - import.
If it doesn't work go to window>settings pref>plugin manager>
then load the dwg translator.mll
i'm using 7.0
Nov 5, 06 3:18 pm  ·
