What is the command for extrude planar surface in Rhino?
burnt123
I'm working in Rhino. I was wondering what the command was for extrude planar surface.
I have been using "extrudecrv" in the command line and unfortunately that is the wrong command for what I am trying to do.
Apr 18, 12 12:55 am
blah
ExtrudeSrf
Apr 18, 12 1:17 am  ·
accesskb
rhino is probably the easiest software to use... if 'Extrudecrv' or some other tool doesn't work try the other extrude tools that popup when you're typing that command... you know.. when you type in 'E' all the commands with 'E" show up.. similar when you type in 'EX', all commands with 'ex' show up .....
May 29, 12 11:57 pm  ·
ecnal
If you have a planar surface that you want to extrude, ie: give a thickness to, the command is extrudesrf.
Google is your friend.
May 30, 12 4:15 am  ·
kubo
If you must use extrudecrv:
Dupborder > Extrudecrv
May 30, 12 11:00 am  ·
