Easter Turducken!!!!
Smokety Mc Smoke Smoke
Just in time for Easter ... check this out
Apr 14, 06 6:17 pm
le bossman
interesting. my uncle used to make real turducken all the time.
Apr 14, 06 6:51 pm  ·
strlt_typ
instead of a dremel maybe a hot knife would make a cleaner cut
Apr 14, 06 6:58 pm  ·
liberty bell
We will be coloring eggs today in our household: here is the system developed by the Georgia Egg Board for boiling eggs pre-coloring:
*note: water should cover the eggs by 1 inch, so use a tall pan, and limit cooking to 2 dozen eggs at a time.
1. Lay the eggs in the pan and add the amount of cold water specified. Set over high heat and bring just to the boil; remove from heat, cover the pan, and let sit exactly 17 minutes.
2. When the time is up, transfer the eggs to the bowl of ice cubes and water. Chill for 2 minutes while bringing the cooking water to the boil again. (This 2 minute chilling shrinks the body of the egg from the shell.)
3. Transfer the eggs (6 at a time only) to the boiling water, bring to the boil again, and let boil for 10 seconds - this expands the shell from the egg. Remove eggs, and place back into the ice water.
Chilling the eggs promptly after each step prevents that dark line from forming, and if time allows, leave the eggs in the ice water after the last step for 15 to 20 minutes. Chilled eggs are easier to peel, as well.
NOTES : The perfect hard boiled egg has a tender white, and a yolk properly set. There is not the faintest darkening of yolk where the white encircles it (a chemical reaction caused by too much heat in the cooking process). Eggs cooked this way can also be peeled neatly.
The system described here, developed by the Georgia Egg Board, takes a bit of fussing - but it really does produce an absolutely Perfect Hard Boiled Egg!
I'm currently 14:27 into the 17-minute rest period. Good luck making a Turducken everyone - I'm not that ambitious (though my dad did it one year.)
Apr 15, 06 9:26 am  ·
sporadic supernova
lol .. good luck LB ..
the receptionist is making rum balls and getting them to work tommorow.. :) . so i'll pass on the eggs
I guess no site work for me tommorow ;)
Apr 15, 06 9:33 am  ·
AP
that looks delicious Smokety. anything worth doing is worth doing with power tools...
Apr 15, 06 9:47 am  ·
