Help me share a Rhino model
RAArch
I need to be able to email a Rhino model to a client in order for them to view it. So i need to keep the file small enough [exporting as a .dxf is not an option] and the client will need some sort of 3D viewer to look at it. Unfortunately he is mac based to downloading a Rhino viewer isn't an option.
Is there a viewer that you know of that will run off of OX while reading a .3dm file or some other similar file that would be small enough to email? Currently the rhino model is 3megs, i could email up to 5megs or so.
thank you in advance.
Jan 12, 06 2:16 pm
For viewing, perhaps eDrawings?
Jan 12, 06 2:37 pm  ·
RAArch
thanks for that pixelwhore, only problem with that is it only supports dxf/dwg from rhino which are too big to email.
but if we end up going the ftp route this will come in handy, so thank you.
Jan 12, 06 2:52 pm  ·
FOG Lite
you try lowering your rendermesh settings before exporting?
Jan 12, 06 3:08 pm  ·
RAArch
yes i did, that knocked off about 3-4 megs from the file, but at 33 megs [as a dxf] is still a far cry from the 5 i need it to be to email. if you have any other tips i'd love to hear them...im a little new to the export game in rhino.
thanks
Jan 12, 06 3:11 pm  ·
garpike
You can control the amount of polygonal faces on surfaces individually.
Convert the simpler objects/surfaces to polygons before converting to a dxf. Select all of the simplest objects like rectangular planes and cubes and convert Nurbs to Polygons under Tools. Set the number of polygons to low (A simple cube should only have two triangles per face).
Leave the more complex forms alone.
This should help.
Also, I am not sure if the rendermesh is saved with a DXF, but if it is, make sure you have the "Save Small" option selected when exporting. This will knock off up 90% of your file size (at least on a native Rhino file)!
Jan 12, 06 3:19 pm  ·
spaceghost
www.yousendit.com
upload. email the link.
no idea about the viewer.
why not just save a series of views and email those?
Jan 12, 06 3:36 pm  ·
RAArch
thanks garpike.
that took off about 10 more megs, but im still at 20+
i think the underlying problem is the main geometry, which is a model of a 727, which is made up of meshes. i didn't personally create this so im at a loss as to what to do to it. perhaps the dxf/ftp route is the only way to go here.
thanks for the input.
Jan 12, 06 3:39 pm  ·
RAArch
thanks spaceghost!! not only was that my favorite cartoon as a child, this will deliver the dxf and our client will be able to view using pixelwhore's viewer.
much thanks.
Jan 12, 06 3:41 pm  ·
Jeff Mottle
I know quite a few people who use:
http://www.fileflow.com/
I personally use it to receive all of the submissions on CGarchitect to avoid killing my server. Looks similar to the link posted above, but migth have a few more features.
Cheers,
Jeff
Jan 12, 06 5:01 pm  ·
_other_
for future reference this FF extension is due to launch soon letting everyone just Torrent everything
Jan 12, 06 7:21 pm  ·
RAArch
thanks everyone.
Jan 12, 06 7:24 pm  ·
garpike
No problem. Now this was a rare good thread. Useful.
Jan 13, 06 8:35 pm  ·
