Acoustic Waterproof Treatment
dia
Hi,
I am looking for, if it exists, a material application for concrete decks and balconies. Specifically, I am designing some buildings where the concrete decks must meet acoustic requirements, ie sound deadening, as well as needing waterproofing.
Is there a verified system of sandwiching a waterproof layer, with a thicker layer of cork or rubber so that you can then paint to finish, or maybe lay tiles over.
Its a bit if a boring topic, but maybe my northern hemisphere compatriots have some products that we don't have down here.
Cheers.
Nov 21, 05 11:04 pm
Suture
this is almost 2 independent systems in one--a roof and a paver. Im sure that they have rubber standoffs to achieve some level of acoustical rating:
http://www.superiorwaterproofing.com/archive1.html
there are also many other pedestal pavers out there.
Nov 21, 05 11:15 pm  ·
Carl Douglas (agfa8x)
It would be pretty hard to fix any kind of cork/rubber over a waterproof layer without penetrating that layer.
I don't know of any systems for it, but I would guess it would be easier to use a flexible waterproof layer (butynol or whatever) over top of the cork/rubber.
Unless you were just going to float a layer of cork and then tiles over the membrane. It is almost impossible to avoid water getting under there somehow.
Nov 21, 05 11:32 pm  ·
tlmII
The section thickness gets to be a little difficult but I once did a terra paver pedestal system which started with two layers of enkasonic over a structural CIP deck, then a drainage course sloped to deck drains with the pavers on pedestals level at the surface. This was for an exterior courtyard space over a high STC performance space.
For my condo jobs at the exterior balconies and walkways we do a drainage mat w/ waterproofing membrane topped with enkasonic and a lightweight concrete for acoustics.
Nov 22, 05 10:19 am  ·
Devil Dog
concrete works for low frequency. mass is really the only alternative to proper sound mitigation in such an application.
if it were my project, i would look at isolating from the underside of the deck. two layers of 5/8 gwb on resilient channels mounted with RSIC clips and 4 inches of concrete should give you close to an STC 60. this assembly will add about 4 inches to the section. is that too much? the key component are the clips since they isolate with rubber.
if you're trying to mitigate structure born impact noise i think this assembly would work. the concrete deck should already be adequate for voice noise.
Nov 22, 05 11:22 am  ·
el jeffe
i wasn't familiar with the RSIC clips - thanks DD.
Nov 22, 05 12:04 pm  ·
dia
Thanks everybody.
Our acoustic engineer is mainly complaining about noise travelling to adjacent apartments laterally. The the choice is to isolate the decks from the structure [obviously not doable], or a combination of waterproofing and sound deadening.
I'm thinking that an initial layer of waterproofing, then a layer of cork, rubber, or a thick fabric solution [enkasonic or simlar nylon, fibreglass], followed by another layer of waterproofing, and then tiling might do the trick. Has to be tested of course....
I had a look at enkasonic
Nov 22, 05 4:10 pm  ·
