Rhino Help: What's a good rendering/material editor plug-in for Rhino?
nappy
Other than Maxwell and Flamingo.
I find that importing stuff from Rhino into 3DS Max to render is a pain...unless someone knows a good way to do it?
Aug 29, 05 11:37 pm
brown666
Have you ever tried cinema4d it's not a plug-in but stand-alone, makes very easy (can also be complex) fast and beautifull renderings... the best i ve ever tried. just export your rhino stuff organized with all the layers the same way as you want your materials
Aug 30, 05 1:46 am  ·
trace™
Brazil
Vray and Final render will have standalone renderers soon, so you should be able to use most 3D packages with them.
Aug 30, 05 8:44 am  ·
Josh Emig
Cinema 4D does have the best stock renderer I've seen, but importing to C4D would be about the same as importing to max, seeing as how they're very similar. C4D seems a little simpler to use than max. Also, C4D is native to Macs, so if you're one of those ...
Aug 30, 05 9:06 am  ·
