3D viz terrain
marrek
Help please!
Roads and pads on terrain in 3d Viz for urban visualisation -
Wondering if anyone can tell me the best way to do this - they should be tools in the AEC tool set.
Any help much appreciated - I use Rhino as well - much better for modelling IMHO
Cheers and Thanks
Jul 11, 05 3:13 am
French
inside max, there's many ways to do this. The most common tools would be either to use the terrain type compound object ( link the contour splines in a single object once they are positionned right, and then apply the compound object over it. produces a rough model that you can subdivide inside the modifier section), or the cross section modifier (same technique to link the spline, then apply modifier cross section, then a surface modifier. a smoother model, but with higher polygon count).
Jul 11, 05 5:58 am  ·
