Rendering decent grass...I need help!
Gabriel Duarte
Well, for moths I have been struggling to manage to render nice grass...but never completely succeeded.
I am quite experienced in Rhino and 3D Max (where I render), but this doubt is kiling me!!!
What is the magic??? What is the trick???
How do I make something look like this??
http://www.west8.nl/W8_News_Events/news-competitions.html
Do you guys use any special software / plug-in?
I manage vegetation in general fairly well (trees, bushes and everything), but grass and other kinds of "fibers" covering large surfaces just don't work with me. They look dull, flat and the tilling gets too visible when looking far from above.
Please, help me!
Mar 9, 05 9:39 am
mauOne™
MAX + Vray + displacement modifier does it for me, but i still have to get render times down, the answer id say is displacement, from there on you have to get your settings right and there u will have great grass
Mar 9, 05 9:44 am  ·
montu
Get a good map.
West8 is using as standard max map.
use noise in your bump map tp give it some irregularity and depthh.
Use a littile displacement to get it to vary over its entire surface.
If you use a large noise map that you create it will look like grass!.
Mar 9, 05 9:49 am  ·
wackingboy
photoshop it.
just map out a base color, like you're painting, and add the details in photoshop when you're done (the grass map).
Mar 9, 05 9:54 am  ·
3ifs
the grass in that rendering looks photoshopped to me, but i could be wrong, i have little to no experience with 3D Max,
Mar 9, 05 9:57 am  ·
montu
Most likely the base is rendered standard max map.
and then a layer of near ground and 3 dimensional depth is added in photoshop.
This is the easiest and most time effective approach.
Mar 9, 05 10:33 am  ·
Gabriel Duarte
Thanks everyone!
Well, throughout my research on grass (for rendering means only) I've seen people recommend VRay, but I've never managed to get it!
I couldn't find it nyawhere...Bit Torrent...Kazaa...E-Mule...
If you guys have any clue where to find it!
I will follow your advices and keep trying.
Images of my rendering test results will be posted soon!!!
And thank you one omre time.
Mar 9, 05 10:45 am  ·
trace™
http://www.chaoticdimension.com/
This is where you get VRay. I'll give you a little hint...MR can do the same thing.
Mar 9, 05 10:48 am  ·
Gabriel Duarte
Trace...sorry for my ignorance, but what is MR?
And where exactly can I find the way to get VRay in chaotic dimension?
I'm browsing through their forums but got no clue by far...
Thanks for the hints!
Mar 9, 05 11:00 am  ·
mauOne™
indeed, max has its own displacement
Mar 9, 05 11:02 am  ·
French
MR stands for metal ray, a radiosity rendering program that's somehow similar to vray, but comes for free with max since version 5 or 6 I believe.
Mar 9, 05 11:03 am  ·
ge-ril-a
The dutch guy at 3d cafe has a nice sampler
http://www.3dcafe.com/models/cannabis.zip
Mar 9, 05 11:08 am  ·
a-f
It might be overkill, but for animations try using particle systems:
tutorial
Mar 9, 05 11:12 am  ·
French
In the end, the proposition of wackingboy is the best solution I think. Take a good picture of a nice grass surface in an angle that fits in your camera view and either camera map it or photoshop it.
Mar 9, 05 11:28 am  ·
ge-ril-a
photos of grass are very forgiving
Mar 9, 05 11:40 am  ·
Gabriel Duarte
Apparently, the DEMO version of VRay did the trick for grass seen from a certain distance.
Now I gotta exercise my Photoshop skills to make the grass close-ups!
If you guys have any further comments or suggestions, please, keep posting!
<img src="/images/uploads/grass_01.jpg" border="0" alt="image" name="image" width="340" height="255" />
<img src="/images/uploads/grass_02.jpg" border="0" alt="image" name="image" width="340" height="255" />
Mar 9, 05 12:07 pm  ·
Gabriel Duarte
The posted low-res images don't show the results in a good enough way, but they're looking pretty OK in their larger versions here!
Mar 9, 05 12:10 pm  ·
