Elec outlet suggestion for outdoor kitchen?
Are there decent looking outdoor elec outlets?
Location is a fully roofed outdoor kitchen - alcove arrangement, basically open on one side. Outlets of concern are the ones above the countertop for small appliances etc
Or, just install the goofy bubble housings to pass inspection & then pull them afterwards?
any wisdom?
Nov 8, 22 7:09 pm
I spec'd some really cool pop-out ones on my last project. I'll try to remember the name but I've blocked that entire traumatic part of my life out, and to be fair, have been taking a whole lot of bong rips in my van down by the river these past few months.
Rest assured though, they are out there.
Nov 9, 22 4:38 am  ·
t a z
I've been down that rabbit hole too - you are thinking of this accordion type cover: https://www.hubbell.com/taymac/en/Expandable-In-Use-Cover
Nov 9, 22 4:49 pm  ·
bennyc
try floorboxoutlet.com
Nov 9, 22 12:18 pm  ·
i've spec'ed popups as well, but i've not had an inspector comment on their acceptability for exterior use (& they start at $300/ea)... and IP-44 spill proof is useful, but not listed for wet location
the IP-66 ones I find must be installed in 4" of concrete & typically have gray plastic covers, which i'm not fond of on a quartz countertop
[not to mention I've had listed wet light fixtures that filled with water despite the IP-66 (dustproof & water jet proof)]
...leaning towards an off-the-record suggestion of removing bubbles on a wall mounted backsplash gfci
Nov 9, 22 1:52 pm  ·
or just low profile non-metallic cover
Nov 9, 22 2:06 pm  ·
msparchitect
I use Alrington low profile boxes for exterior outlets. They look so much cleaner than the standard bubble in my opinion. They have siding step boxes as well for a tight fit.
http://www.aifittings.com/cata...
Nov 9, 22 5:36 pm  ·
msparchitect
https://amzn.to/3FYi8Gd
Nov 9, 22 5:39 pm  ·
