Bachelor of architecture
Archicatman
Is a bachelor of architecture good for anything? Could you be hired as an interior designer with it? Also, if you have a bsc in interior design, would it take 2 years for the masters of architecture or would it take longer compared to if you had a bsc in architecture and are moving into masters.
Feb 24, 20 12:19 am
Architecture > Int Des by a cubic light year
A bachelor in arch is worth something, I guess... at least it will get you some decent material for a M.arch application folio but you really should aim for an accredited B.Arch (if available) so you can skip the grad school requirement.  Besides that, you can do int-des with an arch background, no problem, if that is your jam but an int-des cannot do architecture. It's not really the same scope and the skillset developed in most (if not all) int-des programs do not translate well into architecture.
Where are you looking for to go to school and eventually work will affect your options.
Feb 24, 20 12:49 am  ·
Pretty sure we've already covered all this in your other 6 identical threads.  Adulting is hard, I'm told, but if you're having such a hard time picking a direction, maybe you should ask real people instead of throwing questions to an anonymous group on online wankers.
Feb 24, 20 12:52 am  ·
