Recently found myself questioning about the measurement system in Architecture.
Because most countries still use area and height as basic measurements of architecture, but they sometimes don’t really correlate to the actual volume of a building. Which is not an effective measurement considering FAR and building to land ratio as regulations
So if measuring the volume of a building becomes more easier do you think it would become a more standard measurement of space rather than height or area?
Measuring volume is important for the mechanical system... and that's pretty much it. We already have an easy way to measure it thru BIM so I'm not sure what your point it?
Volume, I guess, could be neat from a design point of view, but it becomes useless when it comes time to design the elements within said volume. These are still dependant on the basics length/height/area.
It is crutial for calc and analysis for other discipline engineers. If you really work through a project from sd to ca and close out, you will have no question. Not really understand your point.
Jan 29, 20 11:47 am ·
mdarcht
Not doubting the importance of volume measurements in architecture, but curious if it could also become a factor in regulations like area or height, FAR, etc...(in the future?)
Volume measurement of architecture
Show me a tape that measures volume.
‘coz still the laws do not regulate buildings based on their volume, but mostly depend on height/area
So wondered if volume could be a more precise unit to regulate (let’s say for) diagonal or freeform architecture?
What is the advantage to regulate by volume?
what would the point of a FVR be? Even if someone wanted to build crazy tall floors, they'd still hit the height limits.
