Tensile membrane structure model
G.Palileo
So second year is here (yay?), and I've been tasked with analyzing Frei Otto's 1967 German Pavilion. Now I have to make my own forms and shapes with the same principles, and I was wondering what materials to use that could recreate such tensile membrane structures at a small scale?
Thanks all :)
Sep 6, 18 11:23 pm
tintt
Pantyhose.
Sep 7, 18 12:08 am
Do some research. There are plenty of photos and documents showing Otto in his studio doing tests with soap bubbles and armatures, string, nylon, etc
Sep 7, 18 1:57 am
JawkneeMusic
if you're speaking of cable it generally works as anything.  Get a spring scale, weights, & twine
Sep 7, 18 6:59 pm
do you even known who Frei Otto is?
JawkneeMusic
i'v probably seen the buildings but didn't give a damn
edit: what tripe did you LEAD me to?
JawkneeMusic
im pretty sure there's code for wire in amerika
Sep 7, 18 7:09 pm
Go to an outdoor store and look at the hiking tents for ideas. They have been proven in very high wind, extreme conditions. The flexible poles can be made of carbon fibre or fiberglass. Some versions have the poles inside the tent so no 'cables' at all are required to achieve tension. You can make the structure redundant so the failure of one element will not cause collapse.
Sep 7, 18 7:49 pm
JawkneeMusic
crack out an advanced mechanics of materials book and go into curved beams if applicable
Sep 7, 18 8:31 pm
I did a tensile structure in undergrad and dark grey thread looks surprisingly elegant as small-scale steel cable.
Pantyhose was also a great suggestion.
Sep 8, 18 11:10 am
shellarchitect
Cheese cloth, my first arch. job was to build a kick ass model which featured a tensile canopy.  I believe the model is still on display 10 years later
Sep 12, 18 9:16 pm
