I have also found a second video that seems relatively easy. Here, how would you cut the angles with a handsaw? And what would the angle have to be to join the parts to make the pentagon and the bevel angles to join the pentagons together to make the dodecahedron.
Dodecahedron lamp GCSE Build
nikhilpatil HISTORY · CONTACT
Hi Guys,
I have found s video which shows you how to cut the dodecahedron.
1. Is there any way to cut holes into the pentagon faces after they are cut with angles to make a frame?
2. Can you cut the angles with a handsaw instead of using a miter, and bevel thingy saw?
Thanks for all your help!
SEP 2, 17 4:09 AM · REPLY
nikhilpatil
nikhilpatil
https://youtu.be/PLUer14w708
REPLY
Regards,
Nikhil
SEP 2, 17 4:17 AM · REPLY
nikhilpatil
https://youtu.be/X06qMYKuYG4
REPLY
