Long story short: How might you enable pinning or taping up small drawings/ sketches/ photos on a brick wall? The arrangement needs to be quick, temporary, and removable afterward.
My first thought is to run a horizontal strip of Gorilla Tape to the brick at ~eye level, then tape sheet-tops to the exposed, non-stick tape face.
Put sturdy double sided tape under two strips of black foam board and pin your drawing on all 4 corners to the foam. If you make the strips long enough, your drawings will all hang at a common height.
Brick wall: I need to pin or tape up
Other ideas?
Thanks in advance...
tapcon?
http://community.homedepot.com/howto/DiscussionDetail/Hanging-on-a-brick-wall-9065000000007jW
drills.
If you were an interior designer, I'd recommend you just move the wall. No biggie right? It's just a few lines on a page.
Gaffers tape. Strong enough and leaves no residue.
