Looking for a verb that would describe turning of the heat in a building long-term
annikaeriksson-lindberg
Hi!
I'm writing a paper for my master thesis and I'm looking for a verb or a term describing when you consciously turn off the heat in a building as a result of it not being used anymore, and because it would be too costly to keep it running. There is a word for it in Swedish which is "kallställa" which would literally be translated to "cold set", but I can't find an equivalent word in English.
All help appreciated,
Annika the architecture student
Mar 23, 16 1:31 pm
Winterization.
Mar 23, 16 1:55 pm  ·
Thanks!
Mar 23, 16 2:14 pm  ·
Wellllll I thought when you winterize, you and shutting down everything, mechanical and water? You winterize so pipes don't freeze.
Mar 23, 16 3:17 pm  ·
I'm assuming the student understands the detrimental effects of turning off the heat without draining the pipes (at a minimum).
Mar 23, 16 4:08 pm  ·
What kind of structures, often of a very advanced design, cannot be winterized?
Mar 23, 16 8:17 pm  ·
Do tell.
Mar 23, 16 8:19 pm  ·
gruen
Hard to turn off inflatable structures.
Mar 23, 16 8:25 pm  ·
A lot of backcountry ski huts don't have running water so no pipes to freeze, and turning off the heat means not putting another log in the fireplace or wood stove. Some are starting to get solar panels though.
Mar 24, 16 7:54 am  ·
Turning off the heat, is that not what sleazy landlords to when the rent isn't paid?
Mar 24, 16 8:26 am  ·
