"print" graphics on wood
lifeform
hey.
anyone have any thoughts on how to print graphics (text + line drawings) onto plywood in an elegant way?
trying to avoid stenciling, looks too cheap.
tanks.
Jan 21, 05 3:05 pm
you could try screen printing, which is basically an advanced form of stenciling.
Jan 21, 05 3:07 pm  ·
acetone transfer
Jan 21, 05 3:13 pm  ·
sahar
You could use acetone transfer.
Jan 21, 05 3:14 pm  ·
9SquareGrid
Laser Cutter...
Jan 22, 05 7:01 pm  ·
Raj Patel
agreed: Laser Cutter.
Jan 22, 05 7:06 pm  ·
BPhresh
Try your best local print shop. I have seen ones with hizzuge flatbed printers where you can pass through any material up to [i think] 3/4" thick and it prints digital images directly onto the material. Seen the very sharp results on plywood panels and acrylic.
i know these guys do it:
http://www.citycolor.com/mainwindow.htm#
maybe its da same process as one mentioned above but i forgets da proper terminology.
Jan 22, 05 9:30 pm  ·
Raj Patel
Too bad schematics Hektor arent available
Jan 22, 05 9:47 pm  ·
iwish
just do an inkjet transfer. its pretty easy. You can buy the transfer paper, or make your own. There are several different ways to do it.
Jan 24, 05 1:25 pm  ·
vado retro
try doin a serigraph
Jan 28, 05 7:51 pm  ·
Clancy Pearson
I run sheets of veneer through our epson stylus pro 10000. The ink saturation is quite beautiful. (44 inch wide)
Jan 28, 05 7:56 pm  ·
