SQUIGGLE-??
sterling hall
i have heard there is a 'SQUIGGLE' plug-in or something of the like to work as an add-on with ACAD.
does anyone know anything more @ this ? is it an actual program ? etc> thanks for any help -
Dec 11, 04 10:39 am
ArchAngel
It's a (.pen) file for use in processing .plt files with software like buzzsaw apprentice etc.
They might make a .ctb now - not sure.
Dec 11, 04 12:12 pm  ·
ArchAngel
SQUIGGLE INFO
http://www.signaturecad.com/downloads/Squiggle5UserManual.pdf
Dec 11, 04 12:15 pm  ·
xtbl
blech! those look terrible!!! just draw by hand.
Dec 11, 04 3:33 pm  ·
kissy_face
you can make a squiggle in Illustrator as a pattern brush. plot to file as an eps and then change all the lines to your brush.
Dec 11, 04 11:45 pm  ·
Ms Beary
cris- those are pretty bad indeed. there is a napkin command in autocad that does the same. but it looks equally as ridiculous.
Dec 12, 04 12:45 pm  ·
threshold
Well I actually like Squiggle and use it for presentations often. The newer versions round-trip the .dwg file which is nice. You open it in Squiggle, apply your custom squiggle settings (of which there are many options to control) save again as a dwg and open back up in Acad for tiles, notes… and print directly out of acad.
Squiggle works really well for printing on Arches and water coloring over. If you f-up your rendering just print another and start painting again.
Dec 12, 04 4:15 pm  ·
